07-19-2022 07:19 AM
Good morning,
I upgraded to the 4g plan on July 14th but still am getting 3g speeds (0.5-1.5Mbs) almost a week later.
Phone ( Samsung Galaxy Note 9) shows 4g 5 bars in notification area but Open Signal app shows connected to Telus towers at 3g.
Before upgrading I did look at the Coverage Map which showed 4g available is in my area so I went ahead and upgraded my plan.
How can I get the 4g speeds, or did I waste a month of upgrading costs? It's it reality not available and I need to downgrade to my old plan?
Thank you,
Jacqui
07-19-2022 12:22 PM
If the Signal App shows you are connected at 3G, check you phone settings. Even regular 3G plans connect at LTE but throttled speeds.
07-19-2022 07:24 AM
@JacquiG I think you have rebooted your phone already?
Maybe try to reseat your sim once (power off, take sim out for a minute before putting it back and power it back on)
If possible, test it in another area different from where you are now
07-19-2022 07:22 AM - edited 07-19-2022 07:24 AM
Is the speed slow everywhere? There could ne network congestion.
