07-19-2022 06:34 AM
I changed my plan a day before it expires, it is still not reflecting my new plan on my account status
07-19-2022 12:33 PM
Try refreshing your browser but you click change your plan on your renewal date.
Check after that date.
07-19-2022 07:19 AM
@Jeff14 so, your plan is renewed but renewed on the old plan now?
You are ok to use the old plan for another 30 days or you rather have it changed to the one you want?
If it is still on your day 1 or 2 of your new cycle, I think you can try to message PM Support and see if they can change it for you and just charge you the difference.
Please open ticket with them:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
