Upgraded to $35 plan (2GB promo?)
adnerb68
Hi all, I upgraded from the $15 plan to the $35 dollar plan 4 days ago and now there is a 2GB promo when you sign up for the $35 plan.  Is there a way I can get that extra 2GB added? or would I have to deactivate and then reactivate?  Thanks in advance.
8 REPLIES 8
@adnerb68
but if you need to upgrade, it's not qualify, but you can try to Contact Customer Support Agent by  ,
to ask them is better way and them only they know right answer for you, or maybe they give you a offer for 6 month for it,
Here’s How To Contact Customer Support Agent by CS_Agent,
  • you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck...
LeePublic
@AE_Collector I feel the same way too! The promos keep on extending and are very frequent, hoping a permanent bump in data is on the way! My bet is a 1-2 GB boost in data for the $35+ plans.
No that was Carnac the Magnificent! But absolutely one of the best skits on Carson!
AE_Collector
@AE_Collector   Do you have a terbin like he wore on the "Tonight Show" with Johnny Carson, too?
Meow
2GB promo is for new activation only.
How long have you been with PM? If it is for few months only then it make sense to create new account. But consider cost of new SIM, loyalty, referrals rewards, etc.
@adnerb68
The “Kresgin” in me thinks changes to data included in some or all plans will be improved soon. Maybe our Christmas gift from PM this Nov/Dec will be a bump in permanent monthly data rather than a one time add-on. The constant promo adding 2GB would seem to indicate a likely permanent change before long. To me at least. Then you can re-evaluate your data needs and possible change your plan down in price a little from $35.
AE_Collector
LeePublic
If you decide to port out and back, I'd advise looking at your rewards before doing this, (Loyalty, referral, community) if it is a good amount, I'd not switch.
Dunkman
@adnerb68
The 2GB data bonus promotions is only for new activations.  Not for upgrading plans.  Existing customers who upgrade their plans do not qualify.
You can get this promotion if you activate a new plan with a new number/SIM card.
