Upgrade to a 5G subscription from current 4G plan
Liam98
I currently have a 4G plan at 60 GB for 3 months, I am not given the option to upgrade to 5G which is a deal breaker as I purchased a new phone that is 5G capable.
HALIMACS
@Liam98
Your 5G speeds will vary significantly depending on environmental factors.
You will likely find that your 4G speeds are more consistent and quite suitable for most browsing needs.
Chalupa_Batman
Hey @Liam98
I too am using a 5G plan but on a 4G phone. It was more about the data bucket for me. You can always upgrade to a 5G plan if you wish. And if there is a plan there that says new customers only, you can always reach out to a CS Agent and ask very politely if you can upgrade.
Phil_Adelphus
@Liam98   Do you mean when you log in to your account and select ALL under change subscription you don't see the 5G plans?
