Update Referral Code
lsherbo
Hi I'd set up an account for myself.  Then I set up another account for my daughter.  I should have used my own referral code for my daughter, but I didn't.  Is it possible to make that correction now?  It's been less than one day since I made this error.
jlarocque96
@lsherbo
Shucks! Easy mistake to make.
Start a chat and explain what happened.
https://publicmobile.ca.ada.support/chat/
They should be able to help you!
Good Luck!
DDM69
They have done this for me previously.  Request help with this and hopefully they will accommodate you.
Welcome to Public Mobile 😁
If you used another referral code, that can't be changed. According to the help articles, a referral code cannot be used after-the-fact. But, you can try asking by opening a ticket at: https://publicmobile.ca/chatbot
kb_mv
@lsherbo Contact a moderator and explain what happened. They should be able to help you out.
You can contact the moderators one of 2 ways. Open a ticket through the automated ticketing system (SIMON) at the following link;
or you can contact them through direct messaging at the following link (note this way may take longer for a response);
In either case you should receive a reply within 48 hours though typically they are much faster. Watch the envelope icon top right for a reply.
