12-15-2020 01:11 PM - edited 01-05-2022 04:30 PM
12-15-2020 03:28 PM
The same thing had been happening to me ...and I know I have 100 min Talk included which I rarely use. I figured it out that it was only 2 numbers in my contacts that did this and it was the way they formatted when they were added I guess. I don't know why these 2 formatted differently. The format when you look at your contact should be (xxx) xxx-xxxx. If not edit the number.
12-15-2020 01:21 PM
How long you been a PM customer, @dalewils1 ?
Has it always happened?
If you've been a long-time customer, and it always happens, what was the fix the other times?
12-15-2020 01:13 PM
@dalewils1 wrote:AS USUAL GOT MY THANK YOU FOR YOUR PAYMENT AND THE NEXT TIE I WENT T USE THE HPONE I GOT THE MSG SAYING I DONT HAVE A TALK PROGRAM
WHY WHY WHY ???DOES THIS A;WAYS HAPPEN 😞
No, this is the usual way things happen. Which plan are you on? No phone numbers work?
