Unsuccessful porting from Zoomer after 16 hours....
11-15-2016 07:32 PM - edited 01-04-2022 06:22 PM
Tried to port last night, but incoming calls still went to voice mail. Submitted a contact form on the website 8am this morning. Sent a private message to a moderator an hour ago. But still no response of any sorts, or any fix.
What else can I do to get this fixed? I think it is very understandable that people rely on their phones to do a lot of things.
Thanks!!
Service
11-15-2016 07:57 PM
Thanks Luddite. I hope this will get fixed soon...
11-15-2016 07:55 PM
Plan for the worst: a week before response. 😢
Try your Zoomer SIM; if it works just keep using it until it stops.
Meanwhile, if your service goes down you can make phone calls with an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi.
