01-31-2025
08:36 PM
02-01-2025
09:18 AM
computergeek541
Hello, I'm unable to finish the last step in activating my plan. I bought a SIM card at a Telus store and did all the steps, downloaded the app and payment did go through but the last step was to receive a text message and I'm not receiving anything. Please help. Thank you in advance.
01-31-2025 08:48 PM
HI @calvinmckoy
yes, it is a common activation error, you will need support agent to help. You can submit ticket by direct message:
01-31-2025 08:47 PM
Ok, does it give you the option to get the code by email? Click didn't receive code, wait for the timer to expire and click send by email. You might have to do this 2-3 times.
If it still doesn't work, message Public Mobile directly at the link below for further assistance.
01-31-2025 08:41 PM
Hi, I chose a new number with the new SIM
01-31-2025 08:39 PM
@calvinmckoy are you porting your number? Did you keep your old provides sim in your phone to receive that text?
