Unsubscribe from public mobile
gettoitism
I want to unsubscribe from public mobile.
will13am
@gettoitism , be sure to ask support to remove your credit card from the account.  There have been instances reported that deactivated accounts continue to be charged.
@gettoitism  In your account turn off auto subscribe and the plan won’t renew and you won’t be charged again , the account will be closed in 90 days . So you have 90 days to change your mind and make manual payment again to keep it .
Turn auto subscribe off/on
If your unable to log into your account you can always ask support to remove the credit card on file right away also
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
but if you want to keep the phone number port number out to new carrier and that will close the account also
hi @gettoitism just login My Account, go to Payment and Manage Subscription and turn off Subscribed
if you cannot login, then ask support to help to remove the credit card .  Message them
Remember support agent use the Community inbox to reply, they usually reply within 2 to 4 hours.  Please check here for their replies:
