04-10-2019 05:23 PM - edited 01-05-2022 07:09 AM
First of all I am not sure if this is area specific or it is happening in other places as well.
All of my colleague and I are all experience signal dropping, no internet and call/text failure this afternoon. Is our network under maintenance in the area or it is just experience issues? Would be great if PM can get this fixes.
I took a look on network operators, I can see PM 3G, Telus 4G, but non of us can register into those networks.
04-10-2019 06:25 PM
thank you for this info Will13am, this is exactly what i was looking for as well.
04-10-2019 06:24 PM
i am also in Alberta and have had connection problems today. it was bad this afternoon, but now appears to be working fine....for the moment.
04-10-2019 06:16 PM
@JackL wrote:I c, thanks for the information. I'll keep an eye on it.
According to the chart, it does seems like a Telus issue.
I am just wondering if anyone else on the form is experiencing the same.
Yes you are not the only one...patience...
04-10-2019 05:37 PM - edited 04-10-2019 05:43 PM
04-10-2019 05:26 PM
This is a good resource for tower locations in the country.
https://www.ertyu.org/steven_nikkel/cancellsites.html
This is a good resource for Telus outages.
https://istheservicedowncanada.com/status/telus/map
Check these to corroborate the observed experience.
