Unregistered SIM
09-18-2020 05:03 PM - edited 01-05-2022 03:56 PM
Can I get some help?
It's wrote "unregistered SIM"
I can't call
I can't send messages
I need help please
Thx
Service
09-21-2020 09:18 PM - edited 09-21-2020 09:19 PM
@Helpershelper wrote:They might be able to better check his settings or give him a new SIM
Retail locations are not there to provide support for existing Public Mobile customers. And unless the location is a corporate Public Mobile locaiton (there are very few of these), they aren't going to give away a sim card.
09-21-2020 04:47 PM
09-21-2020 04:40 PM
@Prince1 wrote:what kind of mall?
A shopping mall. But they won't fix this.
Was the phone new and never used by anyone when you bought it? Was it still sealed in the box?
09-21-2020 04:40 PM
Most malls have stores like cellular point or something like. They can help activate lines.
09-21-2020 04:36 PM
what kind of mall?
09-21-2020 03:34 PM
If you live close to a mall you can visit them and have them try and activate it. That’s what I did when I signed up for the first time.
09-19-2020 01:19 PM
@geopublic wrote:@hairbag1 The OP @Prince1 had already indicated that he has a selfserve account and has verified that the sim numbers match. So from that it's safe to assume that he already has activated his card. But then again.....🤔
Yes ...you're right.
I'm no expert, but sounds like the phone is suspect. He says it's new but it's acting otherwise. No wonder he's frustrated.
09-19-2020 01:04 PM - edited 09-19-2020 01:05 PM
09-19-2020 01:00 PM
09-19-2020 12:59 PM
@Prince1 wrote:The sim card is from public Mobile
I bought a new phone
And I want to register my sim card of the phone
I cycles the phone and still nothing
Did you go to the top of this page and click on Get Started. There's instruction and guidance that might help you. There's even a Live Chat option.
Please keep us posted on how you make out.
09-19-2020 12:52 PM
09-19-2020 12:27 PM - edited 09-19-2020 12:29 PM
@Prince1 wrote:yes they are the same
I just want to register my sim card on the phone
That's it
Thx
Where did you get the sim card ? Is it a new sim or ? Sounds like you've done everything correct and it should work. Did you buy the phone new or ?
Try cycling the phone off/on and see if that helps.
09-19-2020 12:26 PM - edited 09-19-2020 12:27 PM
@Prince1 if the sim numbers match then your phone is blacklisted.
To verify this use the sim in another phone. If it works then it's your device that is the problem.
09-19-2020 12:14 PM
That's it
Thx
09-19-2020 09:50 AM - edited 09-19-2020 09:50 AM
@Prince1 log into your account and click "change sim card" green arrow on picture below.
It will show you the last 4 digits of the sim card. Now go to your phone and pull out the sim card.
Does the numbers match? If they don't you're a victim of simjacking.
09-19-2020 09:47 AM
So , do you have something to suggest to me?
09-19-2020 09:46 AM
yes
09-18-2020 09:59 PM - edited 09-18-2020 09:59 PM
@Prince1 wrote:Can I get some help?
I can't call
I need help please
Thx
I've actually seen this message on my phone when Public Mobile was having a network outage, However, unrgeistered sim usually means that the service assigned to that sim card has been cancelled, or otherwise not active.
09-18-2020 09:10 PM
The sim is from public Mobile
09-18-2020 09:09 PM
Non the phone isn't blacklisted
I just need to register my sim on the phone
My Samsung Galaxy S10+
09-18-2020 05:19 PM
I can't call
I need help please
Thx
https://www.publicmobile.ca/en/on/get-started
Use this link to see if your phone is compatible and also if it's been "blacklisted" somewhere.
09-18-2020 05:13 PM
@Prince1 Where did you get this sim? Did you try another device? Did you activate it online?
09-18-2020 05:07 PM - edited 09-18-2020 05:07 PM
Has your sim ever worked?
Do you have another phone to try your sim card in?
The phone with that message. Is this a phone that was purchased second hand? Possibly on Kijiji or marketplace?
