09-18-2020 07:28 PM - edited 01-05-2022 03:56 PM
My friend activated usim today and she entered my referrel code.
I got a text message I was sucessfully referred but she didn't get $10 rewards.
How can she receive the rewards?
09-18-2020 09:02 PM
Thank you for your detailed and kind reply.
09-18-2020 08:25 PM
Usually the day after.
09-18-2020 08:00 PM
it will show up within the next 72hours. and it will be deducted on the next month's bill.
hopefully that helps 🙂
09-18-2020 07:54 PM
@msbj1104 if it doesn't show in her account get her to contact the moderators and ask for it to be applied. You can contact them by going to the help menu type contact and click on contact moderator. Further instructions will be there for you.
Cheers
Naepalm
09-18-2020 07:32 PM
Within 72 hours the credit will be applied to your friends account. Usually it's applied next day so tell your friend to check the account tomorrow. If it is not received in 72 hours they would have to contact moderators however since you got the text. It seems like the normal process will complete as usual.
09-18-2020 07:29 PM
