01-09-2023 10:51 AM
I am in the States for the winter. I want to buy a prepaid usa sim card. But my phone must be unlocked. I think it is. I had to unlock it to transfer from Bell. How do I know for sure that it is unlocked?
01-09-2023 11:03 AM
HI @Clooch unlocking the phone is something you have to go through the provider that you bought the phone from originally, not something PM can help if you didn't get the phone from PM
So, please check with your provider from before
01-09-2023 11:01 AM
If any sim card you put in your phone works or is recognized by the phone, then your phone is telling you it's unlocked.
01-09-2023 10:52 AM
@Clooch @Sounds like it is already unlocked if you moved from bell to pm
