Calls
Lychee1
My new SIM card can call everyone but they can’t call me back. I didn’t do a number transfer for my number, I applied for a new one.
2 REPLIES 2
Hi @Lychee1 you might not need to contact support.  It happened to me before, I reseat my sim card and it works  Make sure you reseat s card with a reboot
but if that does not help, then open ticket with CS agent at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Quigley
@Lychee1
You may have to reach out to a Customer Support Agent and have them look into your sim card and provisions for it.
Use the Chat Bot Simon to get a service ticket started.
