Unlocking a PM SIM card
Beastgaming4040
I need help on unlocking my PM SIM card! I tried attempting to unlock it myself but it’s now PM end to unlock it for me!
hi @Beastgaming4040
please submit ticket with agent
@Beastgaming4040 if you know it is a sim pin PUK, follow this
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
         open a ticket with PM Support using this direct link:  https://urlshortner.tiia.ai/Oyn1L6
           **Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply to you there.
Beastgaming4040
I can’t unlock it on my end! PM Needs to unlock on there end
@Beastgaming4040  You need supports help for that
  • Getting support / submit ticket
  • Get support by starting a conversation with virtual Chat box >>>>>>. Click here
  • Or while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking here.
@Beastgaming4040   you sure it is a SIM PUK you are looking for?  if it is a sim pin, try 1111 or 1234  or 0000
or what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK."
      call  Samsung 1-800-726-7864 for a master unlock code.
      The only info you will need to provide is the IMEI and where the phone was purchased|
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or  on an iPhone's About->Carrier Lock showing "SIM locked"
          You have to ask the carrier where you got the phone from for the carrier unlock code.
           (PM would not be able to help with this)
