Unlock iphone
Nkk1
How can I get my iPhone unlocked
@Nkk1
Go to Settings>General>About>scroll down to Carrier Lock…it will indicate the carrier you need to unlock your iPhone.
If it indicates No SIM Restrictions… then it is unlocked.
If you purchased the phone privately then check to see if it is Blacklisted as @HALIMACS recommendation. Dial *#06# to get the IMEI number of the phone.
@Nkk1   unless you got your iPhone from PM or Telus or Koodo, PM won't be able to help
Plese check with the provider where you got your phone from for unlocking the iPhone
@Nkk1
Hopefully it was from a Canadian mobile service provider.   If so, and you can establish which it was, it'll be free for them to 'unlock' it.   If they give you a hard time, tell them the CCTS requires that all mobile service providers must unlock devices that were previously locked to their network.
Have you checked device checker to ensure it isn't blacklisted?
Check the Status of Your Device in Canada | DeviceCheck.ca
hairbag1
What makes you sure that it's locked ?
Yummy
You have to contact previous provider (free) or look at Internet for those unlocking companies (for a fee).
hycm53
Where did you get it? All phones should be unlocked.
