08-10-2022 04:45 PM - last edited on 08-10-2022 06:22 PM by computergeek541
08-10-2022 07:05 PM
Before I hit Reply...I X'd out the info to demonstrate to OP the at-risk text.
08-10-2022 05:55 PM
@8739918888 You should use the links provided by @RossN and ask customer support to change your community username if that is also your tel. number.
08-10-2022 05:33 PM - edited 08-10-2022 05:33 PM
@hairbag1 wrote:WOW...only thing missing is your credit card number !!
You should remove all personal info as this is a public forum...who knows if there could be some bad-guys lurcking in here !!
Wow, how helpful to quote the post so the data is duplicated. 🙄
08-10-2022 05:08 PM
Thanks
08-10-2022 05:03 PM
Thanks
08-10-2022 04:54 PM - edited 08-10-2022 04:59 PM
@8739918888 i guess you are unaware that you are on an open forum ,unless you want to get hacked ,remove your personel info by clicking on the little down arrow in the circle top right corner of your post to edit your post!!
08-10-2022 04:52 PM
contact support team by CS_Agent to change email, and set new password.
08-10-2022 04:51 PM
contact a cs agent to change your email
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
08-10-2022 04:48 PM
@8739918888 wrote:Hello
My name is Yaaqob
please unblock my accoun
my old email was xxx
and I ask you to change it to xxx
because my old email no longer exists erase with gma
and today i tried to pay my bill and i can't because every time i try to log in the system and i have my pin it sends a verification code by email only no text messag
I cannot access my account from xxx xxx xxxx
Today in the Puplic Mobile store where I bought my chip that has become a Koodo store and they say they can't help me and also I don't have the four-digit code to choose the $25 plan and pay my account with my credit card.
