Unanswered calls not going to voicemail
forwardmick
My unanswered calls are not going to voicemail. I have turned my phone on and off, I have not changed anything. Advice?
8 REPLIES 8
Try ##002# (not 4).
Look at
*#62#
*#61#
*#67#
The above should go to something like ..... 5804001
*#21#
The first should also do a reset.
Adding - Let us know the numbers you see.
@forwardmick   likely no new sim card needed
Please message support as advised and let us know how it turns out
forwardmick
I have never set up call forwarding. dialing ##004# says connecting service invalid
forwardmick
Yes, I have been with Public Mobile for years and never had an issue until recently
forwardmick
None of the above. Is it true Public Mobile recently upgraded and I may need a new SIM card?
Message received from trying to place a ticket is that the system for ticket is down and to send message to @CS_Agent here
@forwardmick - have calls been able to go to voicemail with public mobile previously ?
If you have not set up voicemail, see articles here for help: https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail
typo
@forwardmick   did you ever setup any Conditional forwarding before?  If so, the forwarding setup likely broken since the enabling of VoLTE.
Please reset the fowarding back to defaults, dial ##004#   Calls should then be send to voicemail if not picked up
dust2dust
Are you using a 3rd party voicemail service? If so then it's that currently call forwarding is broken.
