@CS_Agent
forwardmick
Ticket not working, told to use this and send @CS_Agent a message.
My unanswered calls have recently not been going to voicemail. Nothing about my plan or phone has changed in years
2 REPLIES 2
HALIMACS
Re the voicemail issue, try this, @forwardmick
To reset voicemail back to default, dial: (this may or may not work depending on the issue, but worth a try)
##004#
HALIMACS
@forwardmick
Use this option to send a ticket:
Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
