09-27-2019 09:14 AM - edited 01-05-2022 07:18 AM
I recently bought two Google Pixel 3 and Public Mobile plans for both. Texts I send from my new phone to her phone do not go through. I can, however, text her from my old iPhone and she can text both my new phone and my old phone from her phone.
Does anyone have a solution for this?
Thanks.
10-12-2019 05:31 PM
@livyer wrote:Hi all,
Thanks for the feedback, but it doesn't address my problem. I might not have been clear. Here is the situation:
1. I bought two new Pixel 3s, one for my wife and one for me.
2. I bought Public Mobile plans for each.
3. My wife can text or call me.
4. I can call my wife, but cannot text her (I send texts, but she does not receive them).
5. My wife can send/receive texts with others.
6. I can send/receive texts with others.
If there are no further iOS devices in the mix here, then I think there's no need to de-register from iMessage (which you can do here: https://selfsolve.apple.com/deregister-imessage/) as recommended by some. It's only iOS devices that might try to originate an iMessage, but even then, they would fall back to SMS.
As a case of TL;DR, I'm wondering if it's feasible to swap SIMs between the phones and seeing if messaging each other works. If @livyer's SIM in Mrs. livyer's phone is able to text livyer's phone (with Mrs. livyer's SIM), then it quickly isolates the issue to configuration of either phone (either blocked/masked on the outbound on livyer's phone, or on the inbound on Mrs. livyer's phone). I'm not familiar with blocking SMS on Android, so just speculating here. Having another phone to try livyer's SIM in (to SMS Mrs. livyer's phone) would be helpful in further isolating the issue.
10-12-2019 04:55 PM
Up and comer??? Do you know how old I am??? I should be a senior giving expert technical (over their head) advice to other seniors!!! And while not offended I cannot help with MicroSoft or Android. Been there, done that, never again.
@88cranston LOL....I only meant up and comer because you are relatively new to public mobile/community. I do bow to your superior technical knowledge especially due to your apparent age?!! Which I will need to access to finally finish setting up my neighbour's phone sometime this weekend.
10-12-2019 04:23 PM
Did you port an old phone number to public mobile? If so, then you will have to send PM moderators your previous account number to fix the issue for you. You could also try a new number, PM will generate options for new numbers based on your location/area of residence.
I don't think the issue is with the phones themsevles, especially if PM is already active on both new phones.
Good luck!
10-12-2019 04:19 PM - edited 10-12-2019 04:25 PM
@livyer I think your best bet right now would be a direct appeal to @CalgaryBen the resident Iphone expert along with @GinYVR who is very good or up and comer @88cranston .
Although just out of logic my offer to help would be:
1. For some reason can the wife's phone block texts only from a specific number?
2. Does he have his wife's number correctly? Looks like he does?
3. Do a carrier Reset OR Reset his phone and start it up from scratch OR put his SIM in another phone and she if she now receives texts from him.
10-12-2019 04:04 PM
I hope someone can help with this, as it is quite frustrating.
Thanks,
10-12-2019 03:42 PM
Hi all,
Thanks,
09-28-2019 08:56 AM
Can you confirm texting from your new Pixel with new number, to any other # works?
You only confirmed texting to your old phone so far. Just trying to confirm your outgoing service on new phone is GTG.
09-27-2019 09:38 PM
@AE_Collector wrote:
@krazykiwi wrote:Not only is this worth trying, it is a must. @srlawren @Anonymous are correct in saying it needs to be derigistered. You can do it with the iphone or via a computer through the icloud account. Because you still have the ipad which you probably had set up to use you phone to make and receive text, calls / facetime, your number needs to be removed from there too.
Don’t forget AE_collector (said that too)...
@krazykiwi hasn’t said therevis an associated ipad on the same Apple ID, I just gave that example of the mess I got into!
Terry
That was my mistake but I meant it just in case they do have other Apple products linked to the phone number.
09-27-2019 03:56 PM - edited 09-28-2019 01:02 AM
@krazykiwi hasn’t said there is an associated ipad on the same Apple ID, I just gave that example of the mess I got into!
Terry
09-27-2019 03:02 PM
@krazykiwi wrote:
@srlawren wrote:@Anonymous I may have missed the new number detail in my haste. Even still, I think you're right that it's worth "try"ing.
But they have new phones and new numbers. I'm not inclined to assert that it's a must. I'm still standing on "try".
If it doesn't fix the problem then they would of course need to re-register back to iMessage.
09-27-2019 02:53 PM
09-27-2019 02:37 PM
09-27-2019 01:03 PM
@srlawren wrote:
@Anonymous wrote:
@livyer wrote:Yes, only I had the old iPhone. I'm not sure what you mean by "remove the iPhone from your Apply device list." I am typing the number directly to text, not using contacts or anything. Both Pixels are new and have new numbers.
I don't know how Apple intercepts texts from the world but try this. Once in, they hold on.
@livyer yes this is what you need to do. More details here at iMore: https://www.imore.com/how-to-disable-deactivate-imessage-iphone-ipad
I used the slightly hedging word "try". I'm not sure about this exact situation where they have new phones and new numbers. Apple has never seen these. So I dunno. Or I've misunderstood things. Not the first time when it comes to Apple.
09-27-2019 12:53 PM
09-27-2019 10:28 AM
09-27-2019 10:16 AM
@livyer wrote:I recently bought two Google Pixel 3 and Public Mobile plans for both. Texts I send from my new phone to her phone do not go through. I can, however, text her from my old iPhone and she can text both my new phone and my old phone from her phone.
Thanks.
Just perhaps she's blocked you --- ha ha ha
09-27-2019 10:12 AM
Check to see if the number is blocked:
Else
09-27-2019 10:02 AM
Use your old iphone. iMessage settings and remove your. phone number from send/receive text.
Might works afterwards.
09-27-2019 10:01 AM - edited 09-27-2019 10:03 AM
Do you still have other apple devices? Apple devices send text messages by data rather than on the voice control channel when talking to one another. I had an iPhone and an iPad on one Apple ID. iPhone screen quit working so I moved my sim to my previous android device and I stopped getting texts from many people because something thought text messages could still be delivered by data to me. I Had to delete the iPhone from my Apple device list somewhere in settings. Sorry I am so vague about it.
Terry
09-27-2019 09:55 AM
09-27-2019 09:53 AM
That's what I am doing and it isn't working. I am using the "Messages" app that came with the Pixel.
09-27-2019 09:49 AM - edited 09-27-2019 03:50 PM
She didn’t have an old iPhone, only you did? Sounds like you may need to remove the iPhone from your Apple device list? This confuses the heck out of me so others may be better able to describe problem. I still get some texts but not all texts since switching back to my old Android and away from my iPhone.
Terry
09-27-2019 09:38 AM
@livyer Try entering the number directly and send a text. Does it work? Are you using Google's native app for SMS? If not, you should because it supports RCS.
09-27-2019 09:36 AM
Yes, I can, for example, text my old iPhone.
09-27-2019 09:18 AM
Are you able to text other phones with your new Pixel? Other funcitons like talk and data work?
Maybe try rebooting your phone. Toggle airplane mode on, wait a few minutes and then off.
