Unable to submit a support ticket through virtual assistant!
LitlLdy
Hi, can someone please try to see if you can successfully submit a support ticket through the virtual assistant plus select where it says click here in the virtual assistant to see if it opens to send a private message to CS_Agent instead of it opening the page to the Community webpage?
When I try submitting a support ticket through the virtual assistant (I always use my browser in private/incognito mode), it gives an error message on the page that opens after I select Click here to submit a ticket↗ !
It gives option in the virtual assistant to send CS_Agent a message if submitting a ticket doesn’t work “If you have any trouble with this link, please reach out to our agents by sending a private message to @CS_Agent in our Community here. ” That’s not the link to send a private message to CS_Agent! That’s the Community’s webpage!
17 REPLIES 17
LitlLdy
Update: For those that see my post….
Submitting a support ticket through the Virtual Assistant/Chatbot is now working again!
@hycm53 , thank you! 🙂
Just trying to get some errors fixed since the update!
hycm53
@LitlLdy wrote:
@hycm53 wrote:
@LitlLdy wrote:
@hycm53 wrote:
@LitlLdy  Try this one to send private message to CS_Agent, it works on my laptop:
@hycm53 , So, you successfully submitted a support ticket through the chatbot?
Thank you but I know how to send a private message to CS_Agent. I wanted others to test the chatbot to see if it is finally working due to @J_PM said the team tried submitting a support ticket through it this morning & worked for them as well as the link the chatbot has to send private message through it to CS_Agent! Somehow works for them but not for many of us! How can we suggest it to other Customers to use when it won’t work for us?
No, I don't try submitted a support ticket through the chatbot.
@hycm53 , ok. That’s what my post is about. Sorry 😕
That's OK, don't need sorry I misunderstood your post, I should said Sorry.
hycm53
@poutineville wrote:
It worked for me a few minutes ago.  Try a different browser.  I was able to get it working in Firefox but had to allow pop up windows.
@poutineville , what worked for you? Submitting a support ticket through the virtual assistant?
Correct.
@poutineville , Thank you.  No matter which browser (in private /incognito mode or regular) I use when I select submit support ticket a new window opens to an error page! I never used to get that before this new update!
Are you doing this on a computer/laptop or mobile device? This info will help Us. 🙂
poutineville
Correct.
poutineville
Correct!
poutineville
@J_PM wrote:
Thank you all for taking the time to try it again. The team is investigating the error! The screenshots are super helpful BTW🙏
@J_PM , Thank you! I can’t even send a private message to CSA about it due to when I try to click send I keep getting errors with anything I type & can not send them the screenshots either so I will leave it in your hands! 🙏🏼 I used to be able to do all that! I feel very helpless when I can’t do something right! Sorry
J_PM
Public Mobile
Public Mobile
@DDM69 , thank you so much for trying. @J_PM says it works for the team this morning! Yet still doesn’t for us!
@LitlLdy
I just tried to submit a ticket via the chatbot and I received a XXX error.
hycm53
LitlLdy
To add to this I now see why Customers end up here in the community to create a post tagging CS_Agent due to that is what it says to do before clicking the link which sends them here! 🙄 Instead of being given the correct link to private message them!
