05-28-2020 02:53 AM - edited 01-05-2022 10:55 AM
I am unable to sign in to selfserve account. Everytime I try to log in I get the following error:
05-28-2020 11:42 AM
@Sch999 For how long you didn't use the account? Was it on Autopay? If no, and it was more than 90 days, your account is already closed then.
05-28-2020 09:41 AM
@Sch999 That message may indicate your account is already closed, especially if your last charge was more than a month ago.
05-28-2020 05:38 AM
@Sch999 try using 1 855 4public from another phone or with an active service - it will ask for your 10 digit phone number to access 611.. You should be able to remove your credit card. Here's a link on using 611. https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352/highlight/t...
Sorry to see you go. Stay safe.
05-28-2020 03:26 AM
05-28-2020 03:00 AM - edited 05-28-2020 03:00 AM
Try doing what @gpixel suggested.
If you continue to have problems contact a moderator using this link.
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
05-28-2020 02:55 AM - edited 05-28-2020 02:58 AM
@Sch999 try using your browser in incognito/private mode. you can also call 611 to disable autopay
