02-26-2021 08:29 AM - edited 01-06-2022 02:11 AM
I filled up account with 50 dollars and tried to renew my plan now because I ran out data. But when I confirm the renewal nothing happens. I get taken back to the main page and the money is still there. Anyone know why? I've done it many times before.
02-26-2021 06:19 PM
Oh yes thats true! A scheduled plan change to the “other $50 plan done right now (While the Canada Wide version is still on the list) and it is problem solved EXCEPT he will have Provincial Only calling until then though any Voice Long Distance Add-on will cover that. If the OP does plan changes to solve data shortages very often it will be very soon that he is on Provincial Calling OR Paying $5 a month more though. Might be worth looking closer at the $15/1Gb add-on as a solution in the future.
AE_Collector
02-26-2021 05:51 PM
In theory there is no reason the OP cannot schedule it to change on next renewal.
02-26-2021 05:39 PM - edited 02-26-2021 05:43 PM
That is probably the bottom line though he says he has done it many times in the past which has never been possible unless switching to a different plan in order to renew early. Or through a Moderator of course. But that is likely what happened seeing the “other” version of the $50 plan sitting there. For the life of me I can’t understand why they don't change it so people can renew early on their current plan when they have run out of data. Any other plan can be accessed for early renewal, it cant be difficult to add the current plan to the list of options.
Meanwhile.... if we knew what the last day was to select current Canada Wide plans at the old price the OP might be able to simply continue “Circling” on the Provincial plan to Burn Off Data before making an Emergency last minute Landing on top of the $50 Canada Wide Plan before it is too late.
AE_Collector
02-26-2021 04:38 PM
I think the OP didnt undertand he couldn't renew the same plan so tried the other option and met success without understanding the consequences of his actions.
02-26-2021 12:53 PM - edited 02-26-2021 12:54 PM
I am assuming that @J0HN means he selected the correct “Canada Wide Calling” $50 plan, then hit the Change Plan “NOW” button and was moved to the Provincial Calling $50 plan. If so indeed that may be a bug assuming that the two versions of the plans are still visible in the plans list (I haven't checked recently) and that he DID select the correct (Canada Calling) one. If so, off to the moderators I would say.
AE_Collector
02-26-2021 10:09 AM - edited 02-26-2021 10:10 AM
You have switched to the plan that has provincial calling only you will need an add on to call out of province. The plan you were on included canada wide calling and will be rising to $55 in the very near future. Had you stayed on it the price would have remained $50. This is not a bug which is why I directed you to contact the moderators to change your plan for you.
02-26-2021 09:43 AM - edited 02-26-2021 10:14 AM
If you already switched OUT of a Canada-wide calling plan - - would recommend contacting the moderators to get switched back into it. (like @darlicious recently provided)
In doing so, make it clear that you do not wish to pay another renewal amount to make that change. Explain to them that you intended to renew early and stay on the current plan.
To contact a moderator, there are 2 methods:
02-26-2021 09:36 AM
So looks like there's a bug, I couldn't switch to the new "$50 for unlimited Canada-wide/U.S. minutes + 8GB data" plan when I click switch plan now but I got in the provincial wide calling plan, both are 50 dollars. Not sure if this is intentional.
02-26-2021 09:23 AM - edited 02-26-2021 09:24 AM
Are you trying to renew the same plan early? Only the moderators can do this. Submit a ticket via the chat bubble icon at the bottom right corner of your screen and the moderators should be in touch to perform the change in the next couple of hours.
02-26-2021 08:33 AM - edited 02-26-2021 08:42 AM
Wait an hour, clear cache and cookies, open incognito page.
Try again.
Is it possible you may have selected to "change on next renewal date"? If so, "cancel scheduled plan change" and select "change plan now" instead.
Alternatively, you could purchase a data add-on. Depends on how close you are to your next scheduled renewal and how badly you need the data.
