12-15-2024 09:34 AM
I used to have a $15 plan and recently took $30 plan for travelling to US. Now I need to switch back to $15 plan. Need help.
12-15-2024 11:30 AM - edited 12-15-2024 11:34 AM
have a quick peek at Telus. They have a plan where you pay $100 and get service for an entire 365 days. Talk/text and a bit of data as long as you use the promo code BONUS100 when you activate. ADDED...also see they have a plan that's same as your old PM $15 / 30 day plan.
12-15-2024 11:22 AM
Thank you. But I dont find any plans less than $30. Freedom mobile is offering a $15 plan for canadawide similar to what I had before. So thinking to move out.
12-15-2024 10:38 AM
@Vjrmk wrote:Ok, thanks. Best to move out then. This is deceiving and not helpful.
Hey @Vjrmk open the app on your phone then once opened, click on Manage Subscription, then click on change subscription. Scroll down and you will see all the plans you can switch to. Honestly, the $15 is no longer available except for Quebec. There should be a $20 plan with 3GB of data. IMO, that is the sweet spot of plans. Take a look.
12-15-2024 10:17 AM
12-15-2024 09:38 AM - edited 12-15-2024 09:45 AM
Unfortunately, PM have change their rules about downgrading your plan…you can’t anymore. You can only upgrade your plan.
Also, the lowest plan now is $19. So on your account. It will list all plans you are eligible for.
