Max Usage history?
capnNorthAMERCA
Hi, how far back can I view for usage history?  I'm trying to view some data back to 2019.
2 REPLIES 2
@capnNorthAMERCA  likely you won't be able to get back usage data that far back.
I don't think Mod would be able to assist unless you have a very good reason to convince  them.
Self serve usage history is available for a little more than 90 days, although anything older than 90 days will require the date to be manually typed in. Results older than 90 days may also be incomplete.  I'm able to get partial usage history all the way back to January 31, 2021.
