09-02-2025
02:46 PM
09-02-2025
02:48 PM
computergeek541
Good afternoon. I recently lost my SIM card and I am unable to receive a text/voice message for the verification, (obviously without a SIM) and I will not get the verification code sent via email, which I’ve tried dozens of times. What are my options? Came into a Telus store but without access to my account, I can’t do a SIM swap. Looking to get some help. Thank you!
09-02-2025 02:59 PM
Hello @ Lettie_Login,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
09-02-2025 02:48 PM
Ask PM to sort this out
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
09-02-2025 02:48 PM
hi @Lettie_Login you will need PM support agent to help . you can submit by direct message:
09-02-2025 02:47 PM
I have someone at Public Mobile to contact you.
