Add on
SKnow
I just tried to buy an add on, I’ve paid for it, but the data is not showing up on my profile.
hi @SKnow
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
Ask PM to check and help
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
SKnow
It’s not showing up on there either
@SKnow wrote:
Should it not show in my “overview”? In my payment history it’s shows that I’ve bought a top up, but not specific to an add on….
In the Overview area...then click Usage Breakdown....there you should see info on your plan plus any add-ons you currently have available to you.
SKnow
Dunkman
@SKnow
The actual data add on can be hard to find.
In your overview section.  Click on Usage breakdown.  Then your various add ons should be shown.
