08-05-2023 12:28 PM
My mother is having problems with her cell. It’s currently not receiving calls or text, but it appears to be still activate as she’s still being billed.
I tried logging into her account, but am not able to receive the Eversafe code through text as it’s not working.
Any ideas?
08-05-2023 01:48 PM
@Annoyed_again we are happy as long as it works 🙂
08-05-2023 01:47 PM
@Annoyed_again ahh good we happy to hear it
08-05-2023 01:46 PM
This worked. But only after resetting password through “forgot password”.
08-05-2023 01:46 PM
Thanks! This worked. Once I reset password, it gave me an option to send code to email. I’m in! Thanks!
08-05-2023 12:55 PM
Hi @Annoyed_again just not receiving inbound calls? Help her to change the network mode to 3G only, it should help
08-05-2023 12:46 PM
It’s says next billing date August 29.
08-05-2023 12:31 PM
try to call 1.855.4PUBLIC, enter 1 for English and then her phone number, it would tell you if account is active or suspended
For login My Account, Have you login to My Account since EverSafe was introduced?
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
If you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support by direct message here:
08-05-2023 12:31 PM
When was the last payment? On your phone, dial 1-855-4pu-blic and enter her number and hear what the recording says. It will say 1 of 3 things.
08-05-2023 12:29 PM
@Annoyed_again !try tapping resend code a few times . You should then be given an option to send code to email instead . If no luck please submit ticket with support to help you re gain access
private message To CS_Agents click
VVVVV Link below VVVVV
