03-24-2026 11:25 AM
Everytime I change province like from Ontario to Quebec I cannot make or receive any phone calls. I've had that problem in the past and it was resolved but for some reason the problem came back;
04-01-2026 06:36 PM
The Volte wasn't on but I won't know until I go back to Quebec. I assume that was the problem.
Tx
03-24-2026 12:00 PM
@suzanneramsay wrote:Everytime I change province like from Ontario to Quebec I cannot make or receive any phone calls. I've had that problem in the past and it was resolved but for some reason the problem came back;
what you meant by you "change province like from Ontario to Quebec" ? you meant you have change a new phone number? or you meant when you travel between Ontario and Quebec?
Try Reset network settings after a device reboot.
if you still unable to make calls, check if your phone is VoLTE compatible on PM's network:
