Unable to log in to self serve account
bedofroses
@All
This is what I get when I try to log into self-serve account using my id and password that I just created. Please let me know if anyone knows how to fix this.
7 REPLIES 7
Good to hear,  @bedofroses !!!
The site is very temperamental... but a bit of patience and tricks of the trade work wonders!!!
bedofroses
Thanks everyone. I guess its one of the case. I logged in to my PC after a day and its working good.
@Tsawwassen wrote:Your user ID would be the same as the email you used to setup your community account.
That's not always the case. The e-mail address used for Self Serve can be different, and the e-mail address to used to setup either Self Serve or Community can be any e-mail address that the customer chooses to enter.
Tsawwassen
Maybe you made a typo when you JUST CREATED your password. Your user ID would be the same as the email you used to setup your community account. I would open up a case with CS - good luck.
@bedofroses  As other have already mentioned about clearing web browser incognito / private  is typically the best suggested path  to access. Your  account and view the most up to date info on your account
HALIMACS
@bedofroses
If you are using a mobile device vs a desktop/laptop, try the opposite.
The self-serve site has been known to be temperamental between those two different platforms.
@bedofroses
What browser are you using?
Try Chrome or Edge but do the clear cache, cookies and incognito before login in.
It is a cache issue on the new website. I am using Chrome with no problem.
