Unable to delete VM greetings
dohadotahmed
Hi,
I wanted to delete my wife's voicemail greeting which I recorded a long time ago. I tried to delete the greeting in every possible way and wasn't able to delete. So can someone please help me to delete this greeting and set it as system greeting that will be great.
Thanks in advance.
dohadotahmed
Yes @Watoko...option 6 the system greeting is not available anymore. Thanks.
Watoko
@Luddite wrote:
http://productioncommunity.publicmobile.ca/t5/Discussions/Navigating-voicemail-options/m-p/85167#M22...
If this post's ideas do not help, her voicemail may need a complete reset. If that happens send a private message to any moderator with her phone number, her email account address, and a description of what has happened.
Just wanted to let you know that for the link you referred to, option 6 to activate the system standard greeting is no longer available. I just tried it as I wanted to do that. 😞
dohadotahmed
Yes I tried...but the old greeting still there. I also tried to delete it and set the system greeting but no luck. Thanks.
KK
Have you simply  tried just recording over the existing one?
