07-11-2025 11:06 AM
Hello
I am managing 3 different accounts for different members of my family and this week I started changing the default subscription they all had (3 different login name, same credit card on the 3 accounts). No problem for the 2 first ones, did it via web browser.
Third one is refusing to upgrade the subscription. When I do it via a web browser, when I click the final confirm, the screen is stuck in "loading" animation. I tried several times on different computer and different web browser, same thing.
So I installed the app on my son phone (the one for which I am having issue upgrading) and same thing, it does not work and says to check the paiment method. I know it is valid but still I tried a different credit card and it does the same. When I try to apply immediately instead of "on renewal", it says paiement failed.
I am kind of stuck now, any suggestion?
Thanks!
07-11-2025 01:53 PM
hi @EricL3 did you try using another browser?
or simple ask PM support agent to help change Subscription for you instead of fixing login
07-11-2025 01:14 PM
CS Agent have been useless. They don't understand that I am managing 3 accounts for my family and they refuse to even look at my case.
Between AI chatbot and CS Agent, support is really terrrible and without this community, I think Public Mobile would go down very fast.
I am now considering other alternatives since I cannot update one of my accounts.
07-11-2025 11:13 AM
I was able to submit a ticket, thank you
07-11-2025 11:09 AM
hi @EricL3
it could be just a browser cache problem, especially when you manage multiple accounts. Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
