09-03-2022
02:41 PM
09-04-2022
03:01 PM
Dunkman
Hello. The website tells me that the email (which I used to activate my phone) is unable to be used to activate my husband's phone. I want to use one acct and one email for 2 phone numbers. Pls help.
09-03-2022 06:33 PM
Each account can use an email and or a alias to that email. Thus only using 1 email.
09-03-2022 02:45 PM
@jpal1999 Unfortunately, PM doesn't permit more than one account per SIM/email/phone number. So you'll need to get a separate SIM and activate a new account with another email for your husband, although an alias email address and same CC can be used for easier management of accounts.
You should also use your referral code for the new account so that your husband will receive 10 points and you get either $1 (old rewards) or 1 point/30 days as long as the account stays active with PM.
09-03-2022 02:44 PM
no option to do that for each account need a separate email. but for the other info you can use the same.
09-03-2022 02:44 PM - edited 09-03-2022 02:47 PM
@jpal1999 @Hi in order for your phone/account to work properly you need a separate email for each account but if you wish both accounts can use the same credit card to pay for their phones
