07-28-2020 12:30 AM - edited 01-05-2022 12:35 PM
Hi,
First time I dialed 1 or called my own number for the voicemail, it was completely silent so I hung up.
Anytime I try again, it asks me for a mailbox number (which I don't have?) and to press star during the greeting (that I didn't record?)
Please let me know, I can't have the auto greeting as my voicemail for work.
Thanks,
Selina R.
07-28-2020 06:12 AM - edited 07-28-2020 06:13 AM
@linasrodriguez wrote:Hi,
Thanks,
Selina R.
Hi @linasrodriguez,
Did you just recently port?
As @Anonymous says above, try the "Reset Voicemail Password" option from logging into your SELF SERVE "My Account".
07-28-2020 12:44 AM
@linasrodriguez dial ##004# to reset all your call forwarding numbers to default and then try holding "1" again
07-28-2020 12:33 AM
Your mailbox number would be your 10 digit phone number.
Try dialing 17785804001.
You might need to reset the voicemail password in your self-serve. It resets to your 10 digit phone number.
You might need to set the call forwarding options in your phone.
But it all should have been set upon activation.
