07-27-2021 07:49 AM - edited 01-06-2022 02:55 AM
My dad has a umidigi bison with a public mobile sim in it and the wifi hotspot doesn’t work it will show up on other devices and you can connect to it but it won’t have any Internet on it I have an iPhone 8 with public mobile sim and my wifi hotspot works any idea what is wrong with the bison?
12-03-2021 02:39 PM
Great! I'm happy to hear it's working!
12-03-2021 01:17 PM
Thanks for the help.
I had tried 'dun', which didn't work because it was rejected on 'Save'.
I added the 'DUN' parameter in Caps and 'saved'. Hotspot still did not work!
Changed APN Protocols to IVP4/IPv6 and the Preferred Network to 4G.
Suddenly, it worked!! WiFi Hotspot and 'tethering'.
I am surprised that the PM tech group has not updated their APN settings info.
I think it is pretty poor they are telling customers that their phone is 'not compatible', when it clearly IS if you have the right settings.
Love the BISON (except for Zello!! I disabled the app without any apparent consequences.)
12-02-2021 08:25 PM
As mentioned in a different thread, I have a 2021 Bison and hotspot works for me.
These are my APN settings:
12-02-2021 08:15 PM
You have to add DUN not dun....or your done!🤣🤣🤣
Lol...sorry I couldn't resist that last play on words.
12-02-2021 08:04 PM
i think that brand device need to backup and Factory Reset, to be working fine.
12-02-2021 07:53 PM
Tried that, but when I tried to 'Save', the message came back 'Carrier does not permit 'dun' parameter'
12-02-2021 07:51 PM
I have exactly the same problem!
The PM 'agent' I corresponded with says that the BISON is not compatible with their network.
BUT, it did work once or twice when I first set it up. I think that there are APN settings that need to be tweaked, but I don't know which ones or the parameters.
Noel
07-27-2021 01:15 PM - edited 07-27-2021 01:21 PM
I learned this information from my dear esteemed
( darlicious - Mayor )
can you Try these settings instead:
MMS proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
MVNO type: GID
MVNO value: 4D4F
or try that one Here
if not working if you can try instead that SIM card in your iphone device to you can try it if is working if is working is issue with device and you can try for factory reset settings.
07-27-2021 01:14 PM
@Gavin7 : There are a couple little differences for some phones. Can you post screenshots of all the APN settings?
07-27-2021 01:12 PM
07-27-2021 12:56 PM
Did the dun thing and it didn’t work.
07-27-2021 12:29 PM
or visit HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
for wifi hotspot visit Here
07-27-2021 09:18 AM
This is the APN settings on my umidigi F2. I added dun in capital letters. It's not case sensitive. I did it so that I will remember what I changed.
07-27-2021 08:16 AM
Okay I’ll try that
07-27-2021 07:55 AM
@Gavin7 , on some umidigi devices you need to include dun in the APN type field. To to APN settings and add it.
