Umidigi F3 cannot send MMS messages
howard0178
My recently purchased Umidigi F3 phone works well, sending and receiving text messages.
However, it refuses to send picture messages. I have triple checked all the APN settings they all look good but it still won't work.
Anyone have any ideas ?
Current settings as follows:
Name  public mobile
APN  sp.mb.com
PROXY  not set
PORT  not set
USERNAME  not set
PASSWORD  not set
SERVER   not set
MMSC  http://aliasredirect.net/proxy/mb/mmsc
MMS PROXY  74.49.0.18
MMS PORT 80
MCC  302
MNC  220
APN TYPE  default,mms,supl,hipri,fota,cbs,wap,xcap,rcs,bip,vsim
APN PROTOCOL   IPv4
ROAMING PROTOCOL  IPv4
APN ENABLED
Anyone have any ideas how I might get this feature working again??
Thanks
Mat2023
I purchased the same phone last week and I am having the exact same issue. Would you please tell me exactly how you managed to be able to MMS messages?
dust2dust
Since we're revived, of course you have your cell data on right? And each time you edit the APN you're saving it, and selecting it to be the active APN, and going in and out of airplane mode to reconnect the network using the updated settings?
Adding - hard reset would be the last thing to try. Please try out the other ideas suggested and give us some updates before you go doing a hard reset.
Timer
@howard0178
first tried all above APN Settings not works,
then those device brand need to do hard reset to be working..
@howard0178   Compare yours with this and try to make the change to MMS Proxy and MMS PORT
Compare the APN settings below, try to update it and save:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MMS Protocol: WAP 2.0
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
Bearer: Unspecified
MVNO type:GID
MVNO value: 4D4F
darlicious
@howard0178
Try this one instead.
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
MMS proxy
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
APN protocol
IPv4
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
HI@howard0178
Try to change these couple ones to :
MMS Port: 8799
