Ulefone Armour 24 mobile data
Moneybags19
I am having this problem now. With the armour 24 can someone help please?
2 REPLIES 2
hi @Moneybags19
your voice calls, both inbound and outbound,  work? text work?
Only data is the issue?
try reboot the phone and Reset network settings
@Moneybags19
With Ulefone , you likely need to update APN.   Please check and update and APN as follow
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN  or dun for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
