05-14-2026 12:27 PM
I'm using an Ulefone Note11 8GB ram and 156GB storage, settings show I'm using 4G. apparently Public Mobile does not recognize thei phone as VoLTE capable, I think it is, what canI do short of buying an overpriced phone?
07-15-2026 03:13 PM
07-15-2026 03:08 PM
IMEI checker has vanished
05-14-2026 01:36 PM
Unfortunately you need a phone 'compatible' with PM network. No matter if your phone is VoLTE compatible by default if it is NOT compatible with PM network either you need a new phone or change provider.
05-14-2026 12:34 PM - edited 05-14-2026 12:34 PM
hi @DoubleD
You might have a 4G/5G phone, and a 4G/5G plan and using 4G/LTE/5G for data, and your phone might support VoLTE, But PM has a VoLTE whitelist and only phones on the list can use VoLTE.
Since you got that text, your phone likely is not on the VoLTE whitelist. If that is the case, while you are using 4G or LTE or 5G for data, when you are making calls, the system will ball back to 3G for voice calls.
When the 3G network ends, you won't be able to use any network for calls with your current phone
check if your phone can use VoLTE using the IMEI checker here:
https://www.publicmobile.ca/en/get-help/articles/volte
