06-09-2022 10:34 AM
I have the Canada wide plan and is heading to the US I just add the unlimited talk plan for the US can I make calls to Canada for free does any one know?
06-09-2022 12:42 PM
The unlimited talk to US is only if you call US from Canada. As others indicated, you need US Roaming Add-ons to call Canada from the US.
06-09-2022 11:54 AM
Call/text is unlimited for those 10 days (not data) and yes you can call Canada
06-09-2022 11:37 AM
06-09-2022 11:03 AM
You have to buy US talk add-on in order to use PM services in USA.
06-09-2022 10:55 AM
@Ind hi only the 10 day US roaming plans will work while you are in the US
06-09-2022 10:45 AM
You’ll need a roaming addon to use your service in the US... there is no unlimited option.
