USA calls
Marilynjoy
I paid for calls to USA. Wont let me in
darlicious
@Marilynjoy
Log into your self serve account using secret/incognito mode and confirm the add on you purchased was the $15/1000 US min add on. If correctly purchased then try rebooting your phone first before dialing the US phone number. What is the area code you are dialing? There are a few excluded area codes that cannot be called.
Answer some questions.
You can't call these numbers:
712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726
Be sure to add a 1 in front of the numbers you're dialing.
@Marilynjoy wrote:
Why cant i call usa
@Marilynjoy   you need US long distance add-on to call US
1000 U.S. Long Distance Minutes - $15.00 (10 Reward points)
or you can call it free by using app.  Download VoIP app TextNow and you can call US and Canada for free using the app
Marilynjoy
Why cant i call usa
dust2dust
Was that the 1000 minute add-on? Or did you accidentally buy a roaming add-on?
