06-25-2020 09:04 AM - edited 01-05-2022 11:50 AM
Hello,
If I'd like to add talk and text while I travel to the USA for about 20 days, should I add two of the USA talk and text add-ons at once? Will that extend that add-on to 20 days or should I add on the additional 10 days from the USA after my first 10 days have ended?
06-25-2020 02:36 PM
great question
06-25-2020 09:17 AM
If you want to purchase two of the same U.S. Roaming Add-Ons, you will have to wait for the first 10-day period to expire before buying the second, or you can contact a Moderator.
06-25-2020 09:12 AM
To add to what was mentioned @Werden203 there is a 24 hour wait time to re-add the same add on. Stay safe.
06-25-2020 09:07 AM
@Werden203 hello the 10 day add ons start the moment you add them so 1 at a time is the way to go😁
06-25-2020 09:05 AM - edited 06-25-2020 09:07 AM
Never add two identical roaming add-ons at once. Not only do roaming add-ons start immediately, but if you somehow manage to add two of these same add-ons so that they're both on your account at the same time, this could cause it to not work at all.
![](/skins/images/02B49C0B2FC614613D221373CF8AAEF5/responsive_peak/images/icon_anonymous_message.png)
