05-20-2022 07:39 PM
Bought the $8 unlimited US TEXT pkg and I can't get or receive texts. Can someone help?
05-20-2022 08:22 PM
Good point I was thinking of calling even though he just got the text...my bad
05-20-2022 07:52 PM - edited 05-20-2022 07:52 PM
HI@JL9 T-Mobile or AT&T don't matter. You probably thinking T-Mobile still have more 3G network. But text can transmitted via 3G and LTE, so the tear down of 3G doesn't matter
05-20-2022 07:49 PM
It is a 2 step process once you confirm the add on purchase check the networks, T-Mobile may be more reliable
05-20-2022 07:48 PM
@adamsolly - if you need to use iMessage or Chat Features (both which require DATA to work), you will need to also purchase a data Roaming addon.
Or, if this is a connect to the network issue, restart your phone or perform a reset of the device's network settings.
05-20-2022 07:44 PM
HI @adamsolly did you manually select AT&T or T-Mobile?
and you sure you have the Roaming text bought? Some people just loaded the fund and unaware they have to go back and back. Please check your Plan details page
05-20-2022 07:43 PM
What phone do you have? Did you connect to AT&T or T-mobile?
You don't need to purchase US roaming text add-on to receive incoming texts while in US.
https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming
05-20-2022 07:40 PM - edited 05-20-2022 07:41 PM
Check that iMessage or RCS is disabled as those need an internet connection. Also, enable the SMS option.
