US roaming
Khalipso
If I get a US roaming plan with talk text and 3G of data, is the talk and text unlimited?  Does it work when in the US Boston area?
thanks @hycm53  for confirming.  Now  @Khalipso can go ahead
And @Khalipso  ,  remember to connect to T-Mobile network., use automatic or manual.  enable VoLTE and check if it works, it helps your voice.  You have to enable roaming data  on the device for data to work
hycm53
I was in Boston on April, US $30 add on worked very good and talk and text was unlimited. If your phone support VoLTE, turn on it or LTE. If your phone won't automatically connect to T Mobil, then manually connect to it.
DennyCrane
Yes and Yes. It's a great value.
Make sure you turn data roaming on on your phone too. And remember that the clock on the 15 days starts ticking the moment you purchase the roaming add-on.
HI @Khalipso yes, with the US Bundle, Talk text are unlimited and you can call Canada and US
T-Mobile has Boston coverage, so , it should work.  In case it does not work very well, you can submit ticket with agent and ask for some kind of compensation
