09-29-2021 03:31 PM - edited 01-06-2022 03:39 AM
I purchased the US add-on for $20 for talk, text and data. My text and data work but I am unable to make phone calls. My phone says it is on T-mobile. I am in Iowa. Any suggestions?
09-30-2021 10:46 AM
I was on AT& T in MSP airport but not able to find AT& T in Des Moines, Iowa
09-30-2021 10:43 AM
@tomclaeys : But were you able to switch to AT&T on the A1?
09-30-2021 10:23 AM
My problem is with my phone (Samsung A1 core). I put the sim in a different phone and it works fine.
Thank-you for all your help
09-29-2021 09:45 PM
Is your phone voLTE compatible? If so do you have it enabled? T-Mobile longer connects non -voLTE enabled devices to its network. AT&T does still offer 3G calling for its customers using older devices that do not support the 4G LTE network..
09-29-2021 05:54 PM
@Anonymous @tomclaeys
my mistake i did found out under My Add-ons not under My Data & Add-ons.
see Photo for Purchasing Add-ons,
can you try manually selecting network,
or you need to contact to CSA,
09-29-2021 05:13 PM
@tomclaeys : The above is incorrect. US Roaming talk and text add-ons appear under Plan Details. Not under My Data & Add-ons.
09-29-2021 04:49 PM
that your Add-on is only for US Roaming - 250 MB Data (10-day) not call
you buy it a wrong one..
*you have to buy this one
Unlimited U.S. Talk, Text and 250MB Data Bundle $20,
you have to Contact Customer Support Agent by CS_Agent ,and Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck..
09-29-2021 04:43 PM
this is my add ons
Data & Add-Ons | Amount Used |
$0 Free Holiday Giveaway: 400min INTL Long Distance ( CA & US) | 36 / 400 MIN |
$0 Free Holiday Giveaway: 500min INTL Long Distance CA & US | 39 / 500 MIN |
100 Minutes Canada-Wide Talk | 8 / 100 MIN |
1GB Add-on | 980.502 / 1024 MB |
250 MB at 3G speed | 51.002 / 250 MB |
US Roaming - 250 MB Data (10-day) | 8.047 / 250 MB |
09-29-2021 03:58 PM - edited 09-29-2021 03:59 PM
While both carriers have good 4G LTE coverage in Iowa AT&T edges out T-Mobile.
09-29-2021 03:52 PM
Reboot your phone. If it still does not connect manually switch to AT&T and see if you get better reception.
09-29-2021 03:40 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
To get the obvious out of the way...you used ( +1 or 1 ) in front of the any area code,
for Example long distance, Add (+1 or 1 ) in front of the any area code,
1416xxxxxxx,
or
+1416xxxxxxx,
both is will going through your call...
Good luck and enjoy the service
09-29-2021 03:34 PM
@tomclaeys : Can you click on Plan details and list all the add-ons you see there? Or post a screenshot. Blank out personal info of course.
There's a problem if you have more than one talk add-on.
