03-10-2018 01:01 PM - edited 01-04-2022 03:41 PM
03-10-2018 01:38 PM - edited 03-10-2018 01:41 PM
@Tocibs, did you check whether roaming data is turned on? It should be in the data setting menu. Also, please check that you did complete the add-on purchase. It's a two step process. Sometimes customers neglect to complete step 1 and end up with funds in the account to but the adfoad but did not do step 2 which applies funds to making the purchase.
03-10-2018 01:37 PM - edited 03-10-2018 01:41 PM
@Tocibs You posted this less then one hour ago, be patient, you are not the only one who is reaching for help!
03-10-2018 01:26 PM
reboot phone doesn't work. messaged mod an hr ago still no answer.....
03-10-2018 01:18 PM
Reboot your phone or set it to airplane mode then back to search. Typically, that's worked for me when I went down south.
03-10-2018 01:11 PM - edited 06-19-2018 12:27 PM
you need send a private message to Click here
In your message put it, please include.
- your account number
- your phone number
- your account PIN
- Detailed explanation of specific your issue
- them can help you a lot nice service Team
Good Luck
