12-08-2023 11:10 AM
12-08-2023 12:13 PM
HI @Soda-pop
yes, Canada-US plan include roaming
Data roaming needs to be turned on
Also, PM uses AT&T or T-Mobile for roaming. While your phone might be able to automatically pick the network, sometimes you need to manually test both networks and see which one works for you
Also, voice could be hard to get, if you cannot get Voice while on AT&T, manually change to T-Mobile
12-08-2023 11:23 AM
Yes, US+Can plan includes all features as plain Canadian plan. Calls, SMS, etc.
12-08-2023 11:17 AM
@Soda-pop Yes it does just make sure to put data roaming on in phone settings . When in the US and make sure you connect to T mobile or AT&T
12-08-2023 11:17 AM - edited 12-08-2023 11:19 AM
as long as you're in Canada or USA, that Can/US plan is gonna work for calls / texts / data.
added...voice calls work best when your cell is volte enabled...do you know if your phone is ?
12-08-2023 11:15 AM
Yes, you have roaming only for US.
