12-08-2023 11:00 AM
Hi I ported to public mobile Nov 26. Its been 10 business days and no two factor texts reach me. Please help this is causing major issues. Thanks!
12-08-2023 12:22 PM
Just got off the phone with Porting Team. It was an issue with the porting. It seemed to only half port over my number so a new request was made. Had to put back in my Fido SIM card to receive the port request, confirm the request and now I wait up to 30 mins to make sure my number is fully ported over. Thanks @Handy1 for your help!
Sorry @Jdf58092 for taking over your tread. Maybe you have a similar issue and calling the Porting team will help.
12-08-2023 12:17 PM
Yes I updated the new SIM card on my account
12-08-2023 11:51 AM
@Geo7 Ok in that case , you might just need contact support and ask them to SIM card swap the number for you to the new physical sim you picked up
send a private message To CS_Agents
12-08-2023 11:51 AM
HI @Geo7
did you update the sim card number on your My Account? Can you login to update it? If you can, go to Profile page, click on the pencil beside sim number and update it with your physical sim number
If you cannot update it yourself or still have problem, please submit a ticket with CS Agent here:
12-08-2023 11:49 AM
Yes I ported from Fido and initially used an eSIM for Public Mobile and kept the Fido SIM card in my phone. Today bought a PM SIM card and deleted the eSIM and still have the same issues. I'll call the porting team to see if they can help. Thanks
12-08-2023 11:40 AM - edited 12-08-2023 11:47 AM
@Geo7 Did you just port a number over to PM ? Did you leave old providers sim in the phone to reply YES to the confirmation text to port ? And does you old provider sim card still work ? If yes then I’ll send you the porting team number private message and they can re trigger the port request for you
12-08-2023 11:38 AM
I have the same issue. Also can't receive phone calls from certain numbers either
12-08-2023 11:06 AM
@Jdf58092 It’s normal for 2FA text from backs to take a week before being re routing to new provider /number . But you said it’s been 10 days already so so thing seems to be a miss . Please use the link to support I sent to you in first reply .to see what can be done to fix the issues
12-08-2023 11:05 AM
All 2FA like banks, uber, etc
12-08-2023 11:03 AM
I don't receive any 2FA texts on any platforms. For example banks, uber, insurance, etc
12-08-2023 11:03 AM
@Jdf58092 Is this just for logging in to your Public Mobile account or is it for all 2FAs, like banks etc.?
12-08-2023 11:03 AM
Do you have service at all? Can you call out and receive calls.
If you cannot receive 2FA by SMS request to receive it by email.
If you did not receive or cannot receive your 2FA code by SMS - Click on: ‘Didn’t get a code’ and you will get more options. Chose email.
12-08-2023 11:01 AM - edited 12-08-2023 11:03 AM
@Jdf58092 There should be option that says “didn’t get code “ tap it do you not get option to send code to email instead ? If same use this direct link to support to help you gain access
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
