US roaming data challenges with https
01-29-2017 09:08 PM - edited 01-04-2022 01:27 PM
Hey guys, just trying US phone, texting, and data for the first time (from Orlando). Phone and texting is working great - connects to AT&T. However, I am having a weird problem with my data. http browsing works fine from a browser - as an example http://www.telus.com - but no sites that requires https - like https://www.shaw.ca, https://www.google.ca. The only https site that seems to work is https://www.publicmobile.ca. The rest just report "the site can't be reached" and that they "took too long to respond". None of my apps work with data either - like gmail, weathernetwork, cnn, amazon, etc. They just throw a connection error. I assume because these apps are also using encryption?! I tried using a vpn client as well and am not able to connect. All of these worked fine in Canada using data. I checked my account and my US add-ons are active and it shows that I am using a small amount of data (for my http browsing). Did I miss setting something up? I setup my apn as per one of the email threads but no luck. Any thoughts? Thx!
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: default,supl,mms,dun
01-30-2017 09:14 PM
Thanks for the replies. Looks like many other people are having similar issues with US roaming data so I will stop messging with my phone and live with it. I have PM'd and they will keep me up-to-date if anything changes.
01-30-2017 01:46 PM
@Tup wrote:Can you try to select T-Mobile instead of AT&T or is a person locked in to who they choose the first time?
@Tup based on @PostPunk's response here, I don't think that's likely to work, unfortunately. 😞
01-30-2017 10:22 AM
01-30-2017 01:00 AM
@kgmer2012 here is a related thread you may want to follow for updates:
http://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Us-roaming-not-working-help/m-p/134240
01-30-2017 12:37 AM
@Shutdown wrote:http://mobilesyrup.com/2017/01/29/freedom-mobile-usa-data-roaming-outage/
Seems AT&T is having issues with their data, so no matter what you do it won't matter.
Good find by @Shutdown.
Could be a temporary US carrier issue.
01-29-2017 11:16 PM
01-29-2017 10:50 PM
Hopefully this is not a feature of US roaming data because there are more https sites them http.
01-29-2017 10:25 PM
Thankd for the response. Great list - here is what I have tried:
- connects to wifi
- data is turned on and roaming
- US data is in my plan
- tried the card in two other phones and they have the same problem with US data (iPhone SE and iPhone 5c)
- deleted and recreated APN
- airplane mode toggled off and on many times
- removed SIM for 5 mins and rebooted
- network is set to 3G
- Phone is Google Nexus 4
- Phone has not outstanding updates
- VPN removed
- finally, I just finished reseting / rebuilding my phone - same problem still exists with data and https
- I sent a private message to @Mary_M last night to see if she had any ideas. No response as of yet but I didn't expect a response that quickly
- Today I opened a ticket with Public Mobile
Thanks for the ideas. Banging my head against a wall with this one and because I am here in the US for only a week I really want to get this working ASAP. Thanks again!
01-29-2017 09:30 PM
Never seen this reported before. All I can offer is the long checklist below. If that fails think you will need moderator assistance. Send any one of them a private message ( @Mary_M for example) with your phone number and an explanation. Coverage is currently:
Mon-Thursday 9am(EST) to 9pm(EST) and Friday, Saturday, and Sunday from 9am(EST) to 5:30pm(EST).
DATA NOT WORKING CHECKLIST
- connects with wifi?
- cellular data turned on?
- confirm data is included in your plan
- go to settings, then general-profile and make sure that there is no existing profile, if there is a profile delete it
- check network is not set to 2G; use auto, 3G, or LTE
- check for operating system updates
- data not used up?
- delete current APN, and re-enter settings
- toggle airplane mode off/on
- reset all network settings; you will need to add back wifi passwords after that.
- remove any VPNs
- remove sim for 5 minutes, then install and reboot
- try sim in another phone and a good sim in your phone
- phone make/model?
- if dual sim use LTE/3G slot
- LAST desperate measure when all else fails; erase all data and restore phone to factory settings
