4 weeks ago
- last edited
4 weeks ago
computergeek541
Heya!
I preordered a Linux phone from Europe and it is understandably not listed on the available compatibility page. I have used the Chatbot to try and find out if the bands it uses are compatible with Public Mobile but the Chatbot is not sure either. The phone I am hoping to use says it has compatibility with:
The chatbot said "Public Mobile’s network compatibility information is listed by frequency (MHz), not by 5G NR band numbers (n1, n78, etc.). Here’s what we can confirm:
Supported Frequency Bands:
Important Notes:
4 weeks ago
@KoKo1917 wrote:Thanks for the link. I am really trying to get away from the Big Tech stuff. I suppose I will have to get another Pixel phone and install GrapheneOS.
You'll have a far better experience using a Gogle Pixel than unknown cell maker like Jolla....at least in Public Mobile world.
4 weeks ago
4 weeks ago - last edited 4 weeks ago
I strongly suggest cancelling the order of this phone. Public Mobile does not have a good track record of supporting VoLTE on devices that aren't from major manufactuers and that weren't intended for primary sale to end users in Canada.
4 weeks ago
probably won't work while in Manitoba, and with more provinces also retiring their 3G network by end of next year ('27). You'll need to have a cell that is recognized by Public Mobile to be VoLTE compliant...not all VoLTE equipped cells are usable with PM. Here's some reading on the subject with a device checker a the end of the article.
https://www.publicmobile.ca/en/get-help/articles/volte
In short...I'd suggest sticking with a North American version of a main stream maker....ie Samsung, Apple etc.
