04-30-2026 04:06 AM
Received same text message as many here. Using Samsung A50 and IMEI check says it won't be compatible. I wondering if a Samsung A17 would be? Is there anything specific in the manufacturer's specs that I should look for, or is this all Public Mobile-specific?
Thanks for the help!
a month ago
Move to Lucky or CHATR this Public Mobile scam affects Samsung S10 too. Unbelievable. You are losing me as a customer. Your refusal to support my Samsung Galaxy S10 on this brand—while simultaneously trying to push me to your sister companies Telus and Koodo to use the exact same network infrastructure—is an absolute scam.Charging me a $15 penalty fee for an artificial lockout that you created is insulting. You are losing a long-time customer because of these greasy high-pressure sales tactics.
05-14-2026 09:50 AM
Contacted CS_Agent and they said it is not compatible:
"I will definitely help you with your request and after I verified the IMEI, the device is not compatible with our network which means, the device won't be working if the 3G network will be gone because the device is not compatible with our network for voLTE."
Going to keep the phone and see if things change between now and the 3G shutdown given that it's a sort of new model. If not, I'll just switch providers. Strangely, IMEI confirmed as compatible on TELUS VoLTE network, which I thought Public Mobile used?
05-12-2026 04:54 PM
I am certain A17 is compatible. It is just too new and not added to the compatibility database yet
But of course, you need to ask PM for the official answer
05-12-2026 04:50 PM
05-12-2026 03:33 PM
I went ahead and bought the A17 5G from Samsung Canada to replace the A50. The IMEI tool says: "Your device is not compatible with our network, or we were unable to find a match in our records" but when I place a call I get "HD+ Calling" and stay on the 5G network, which should mean it *is* using VoLTE from what I understand.
05-12-2026 02:21 PM
Yes purchased brand new in Canada but the specific IMEI on the look up tool for PM keeps saying not eligible.
05-12-2026 02:05 PM
hi @Wowimliv
did you get the phone in Canada? is your A17 a Canadian model (there are other regional version)
A17 Canadian model should work with PM VoLTE
05-12-2026 01:58 PM
Got the A17 but my IMEI number shows as not compatible when the phone is advertised as a solution for the 3g shut down. Will it still work since its VOLTE or does it need to be on the PM white list?
04-30-2026 04:38 AM - edited 04-30-2026 04:38 AM
Yeah, it's a bit old. A17 is inexpensive and sufficiently similar with some upgrades. Thanks again!
04-30-2026 04:16 AM - edited 04-30-2026 04:17 AM
Yes the Samsung A17 will be VoLTE compatible since it is the latest A series for 2027.
Your Samsung A50 is 7 years old and considered too old.
